Hello
I got the ST7735 working with the photon but only with a dark “LCD”
When I connect VCC and the Backlight with 3,3 V everything works well except the Display is not light as it should be.
When changing VCC to 5 V it getting light as it should be. But as soon as I want to display anything the display stay white.
Also when I start the photon with VCC at 5V connected its always white. The Jumper on the Display is set to 5V.
Next observation is: I have connected the USB to an PowerPack but when I use a USB Power device (Apple12W) the screen is always white
Does anybody has a clue ?
The next test will be to use a extern 5V supply and power Photon and ST7735 separate to see if this makes the change.
Today the photon is connected via USB and I take the 5V from the VIN Pin at the photon.
I use the following test program:
#include <Adafruit_ST7735.h>
#define cs A2
#define dc D0
#define rst 0
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst); // hardware spi
Particle.function("REDRAW",redraw);
tft.initG(); // war initG
//tft.initR(INITR_GREENTAB);
tft.fillScreen(ST7735_WHITE);
tft.setCursor(0, 0);
tft.setTextColor(ST7735_BLACK);
tft.setTextWrap(true);
tft.print("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla");
// tft.drawLine(0, 0, tft.width()-1, tft.height()-1, ST7735_YELLOW);
// tft.drawLine(tft.width()-1, 0, 0, tft.height()-1, ST7735_YELLOW);
tft.drawPixel(0, tft.height()/2, ST7735_GREEN);
int redraw(String command)
if (command=="INIT")
tft.fillScreen(ST7735_BLACK);
tft.setTextColor(ST7735_WHITE);
tft.setTextSize(2);
tft.print("Bildschirm aktualisiert");
if (command=="TEST")
tft.fillScreen(ST7735_BLUE);
tft.setTextSize(1);
if (command=="BOX")
tft.fillRoundRect(69, 98, 20, 45, 5, ST7735_RED);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_GREEN);
return -1;
and I use this ST7735 board:
