My particle files are stored on dropbox so they can be accessed by a desktop iMac and a remote laptop. Files appear and compile correctly in Workbench on the iMac but seem to be treated as Arduino files and won’t compile when opened on the laptop. I’m saying this because none of the local compile icons appear at top-right of the screen, or the device and os selectors at the bottom right.
Any suggestions on what settings I have incorrect?
Below is the ‘audit environment’ report:
"username": "xxxxx",
"workspace": {
"name": "simpleGateway",
"isWorkspace": false,
"folders": []
"cli": {
"binpath": "/Users/Andrew/.vscode/extensions/particle.particle-vscode-core-1.4.8/src/cli/bin/darwin/amd64/particle",
"ok": true,
"version": "1.42.0",
"installed": 1560511756514
"localCompiler": {
"ok": true,
"dependencies": [
"id": "deviceOS@1.1.0",
"ok": true
"id": "gcc-arm@5.3.1",
"ok": true
"id": "buildtools@1.0.3",
"ok": true
"id": "buildscripts@1.5.1",
"ok": true
"id": "openocd@0.10.0-particle.1",
"ok": true
"id": "deviceOS@1.0.1",
"ok": true
"id": "deviceOS@0.9.0",
"ok": true
"id": "deviceOS@0.7.0",
"ok": true
"platform": {
"os": "darwin",
"type": "Darwin",
"release": "18.6.0",
"arch": "x64",
"path": {
"key": "PATH",
"value": "/opt/local/bin:/opt/local/sbin:/Users/Andrew/anaconda/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin"
"homeDir": "/Users/Andrew",
"particleDir": "/Users/Andrew/.particle",
"localCompilerToolchainDir": "/Users/Andrew/.particle/toolchains"
"env": {
"TMPDIR": "/var/folders/y6/400sg8n50mg6bfy36_ywrq100000gq/T/",
"__CF_USER_TEXT_ENCODING": "0x1F7:0x0:0xF",
"SHELL": "/bin/bash",
"HOME": "/Users/Andrew",
"Apple_PubSub_Socket_Render": "/private/tmp/com.apple.launchd.AHaQiCX3LB/Render",
"SSH_AUTH_SOCK": "/private/tmp/com.apple.launchd.1IMz9gKLUK/Listeners",
"PATH": "/opt/local/bin:/opt/local/sbin:/Users/Andrew/anaconda/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
"LOGNAME": "Andrew",
"XPC_SERVICE_NAME": "com.microsoft.VSCode.36840",
"USER": "Andrew",
"XPC_FLAGS": "0x0",
"VSCODE_NLS_CONFIG": "{\"locale\":\"en-gb\",\"availableLanguages\":{},\"_languagePackSupport\":true}",
"VSCODE_NODE_CACHED_DATA_DIR": "/Users/Andrew/Library/Application Support/Code/CachedData/c7d83e57cd18f18026a8162d042843bda1bcf21f",
"VSCODE_LOGS": "/Users/Andrew/Library/Application Support/Code/logs/20190630T002610",
"VSCODE_IPC_HOOK": "/Users/Andrew/Library/Application Support/Code/1.35.1-main.sock",
"VSCODE_PID": "11942",
"PWD": "/",
"SHLVL": "1",
"_": "/Users/Andrew/Applications/Visual Studio Code.app/Contents/MacOS/Electron",
"AMD_ENTRYPOINT": "vs/workbench/services/extensions/node/extensionHostProcess",
"PIPE_LOGGING": "true",
"VERBOSE_LOGGING": "true",
"VSCODE_IPC_HOOK_EXTHOST": "/var/folders/y6/400sg8n50mg6bfy36_ywrq100000gq/T/vscode-ipc-af308f77-eeb1-465c-8f2d-9c6d7c3e5028.sock",
"VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
"VSCODE_LOG_STACK": "false",
"VSCODE_PREVENT_FOREIGN_INSPECT": "true",
"ELECTRON_RUN_AS_NODE": "1",
"APPLICATION_INSIGHTS_NO_DIAGNOSTIC_CHANNEL": "true"
"versions": {
"http_parser": "2.8.0",
"node": "10.2.0",
"v8": "6.6.346.32",
"uv": "1.20.3",
"zlib": "1.2.11",
"ares": "1.14.0",
"modules": "64",
"nghttp2": "1.29.0",
"napi": "3",
"openssl": "1.1.0h"
"vscode": {
"appName": "Visual Studio Code",
"appRoot": "/Users/Andrew/Applications/Visual Studio Code.app/Contents/Resources/app",
"machineId": "9cf72aff7f896c8e1003701f915ec09eb60aa779df4ab454b0093c8eaef8fcd2",
"sessionId": "be6aac90-2c4c-4b68-8e0b-8f9c82afa7f61561818371339",
"version": "1.35.1"
"extensions": [
"id": "ms-vscode.node-debug",
"version": "1.35.2"
"id": "ms-vscode.node-debug2",
"version": "1.33.0"
"id": "ms-vscode.references-view",
"version": "0.0.27"
"id": "marus25.cortex-debug",
"version": "0.3.1"
"id": "ms-vscode.cpptools",
"version": "0.24.0-insiders3"
"id": "particle.particle-vscode-core",
"version": "1.4.8"
"id": "particle.particle-vscode-pack",
"version": "1.4.8"
"id": "particle.particle-vscode-snippets",
"version": "1.4.8"
"id": "particle.particle-vscode-theme",
"version": "1.4.8"
