I've been desperately trying to get my Xeon to run BLE and continue to bump into issues.
I'm using the latest version of Visual Studio Code on Mac OSX. My device has 1.5.2.
The code I am trying to flash is from the UART example with the addition of me trying to control the LED
Every time I flash the code, it says successful. But changing the UUID or adding the LED control does not take effect for some reason, which leads me to believe it's still running the old code?
Executing task: make -f '/Users/.../.particle/toolchains/buildscripts/1.9.2/Makefile' flash-user -s <
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION
Creating /Users/.../.../Developer/Particle/BLEGPS/BLEGPS/target/1.5.2/xenon/platform_user_ram.ld ...
text data bss dec hex filename
8348 108 1108 9564 255c /Users/.../.../Developer/Particle/BLEGPS/BLEGPS/target/1.5.2/xenon/BLEGPS.elf
dfu-suffix (dfu-util) 0.9
Copyright 2011-2012 Stefan Schmidt, 2013-2014 Tormod Volden
Suffix successfully added to file
Serial device PARTICLE_SERIAL_DEV : not available
Flashing using dfu:
dfu-util 0.9
ID 2b04:d00e
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 8456
Download [=========================] 100% 8456 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
*** FLASHED SUCCESSFULLY ***
Press any key to close the terminal.
// This example does not require the cloud so you can run it in manual mode or
// normal cloud-connected mode
SYSTEM_MODE(MANUAL);
const size_t UART_TX_BUF_SIZE = 20;
void onDataReceived(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context);
// These UUIDs were defined by Nordic Semiconductor and are now the defacto standard for
// UART-like services over BLE. Many apps support the UUIDs now, like the Adafruit Bluefruit app.
const BleUuid serviceUuid("6E400001-B5A3-F393-E0A9-E50E24DCCA9F");
const BleUuid rxUuid("6E400002-B5A3-F393-E0A9-E50E24DCCA9F");
const BleUuid txUuid("6E400003-B5A3-F393-E0A9-E50E24DCCA9F");
BleCharacteristic txCharacteristic("tx", BleCharacteristicProperty::NOTIFY, txUuid, serviceUuid);
BleCharacteristic rxCharacteristic("rx", BleCharacteristicProperty::WRITE_WO_RSP, rxUuid, serviceUuid, onDataReceived, NULL);
void onDataReceived(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context) {
// Log.trace("Received data from: %02X:%02X:%02X:%02X:%02X:%02X:", peer.address()[0], peer.address()[1], peer.address()[2], peer.address()[3], peer.address()[4], peer.address()[5]);
for (size_t ii = 0; ii < len; ii++) {
Serial.write(data[ii]);
RGB.control(true);
RGB.color(255, 0, 0);
Serial.begin();
BLE.on();
BLE.addCharacteristic(txCharacteristic);
BLE.addCharacteristic(rxCharacteristic);
BleAdvertisingData data;
data.appendServiceUUID(serviceUuid);
BLE.advertise(&data);
RGB.color(0, 255, 0);
if (BLE.connected()) {
RGB.color(0, 255, 255);
uint8_t txBuf[UART_TX_BUF_SIZE];
size_t txLen = 0;
while(Serial.available() && txLen < UART_TX_BUF_SIZE) {
txBuf[txLen++] = Serial.read();
Serial.write(txBuf[txLen - 1]);
if (txLen > 0) {
txCharacteristic.setValue(txBuf, txLen);
