Hello,
I have always been familiar with using SPI libraries where I can define the SPI pins. I was not aware of this “hardware SPI”. What is the difference?
Anyways, I built some PCB’s with the assumption of the library allowing me to choose which pins are what, and it doesn’t seem to be the case? Is there a software SPI library out there that I can use? I have not had much luck so far.
@Mahonroy, hardware SPI refers to hardware assisted SPI which removes the work from the application. Software SPI is simple to implement. I’ll post some code (when I get home) for a software SPI function which replaces the SPI.transfer() hardware SPI function.
inline __attribute__((always_inline)) uint8_t softSPItransfer(uint8_t data) {
uint8_t b=0;
for (uint8_t bit = 0; bit < 8; bit++) { // walks down mask from bit 7 to bit 0
(data & (1 << (7-bit))) ? pinSetFast(mosiPin_) : pinResetFast(mosiPin_); // write the outgoing bit
pinSetFast(clockPin_);
b <<= 1;
if (pinReadFast(misoPin_)) b |= 1; // Read the incoming bit
pinResetFast(clockPin_);
return b;
