The problem is that I get a bunch of false-positive switch changes. I have checked the connections and they are all good. Is there any library that can be used to dampen these changes?
Also, is this the best way to monitor for switch changes?
You need to debounce switch inputs to ensure that you filter out spurious signals. I have a simple I/O scanner library that I have used for years and recently ported to the Particle environment that you may find useful.
You need to call the scan function in your loop, but with a delay of at least 10mS (could be longer depending on how bouncy your contacts are.) Here is a short example:
// Define the Pins and the inputs/outputs
int door_sensor_pin = D2;
int bag_sensor_pin = D3;
int door_opened_pin = D4;
int bag_sensed_pin = D5;
DigitalInput door_sensor(door_sensor_pin, INPUT_PULLUP, false);
DigitalInput bag_sensor(bag_sensor_pin, INPUT_PULLUP, false);
DigitalOutput door_opened(door_opened_pin, false);
DigitalOutput bag_sensed(bag_sensed_pin, false);
// Determine the scanning rate for debounce.
IntervalTimer scan_timer(10);
scan_timer.Start();
// Delay I/O scanning for debounce.
if (scan_timer.Expired())
scan_timer.Reset();
door_sensor.Scan();
bag_sensor.Scan();
// Reflect the input sensors to the outputs.
door_opened.State(door_sensor.State());
bag_sensed.State(bag_sensor.State());
// Process the door sensor activity.
if (true == door_sensor.FallingEdge()) // Door Closed
else if (true == door_sensor.RisingEdge()) // Door Opened
The IntervalTimer class I use is a simple one that relies in millis(), which you can do yourself directly with the millis() function.
