I uploaded it again to the core but this time it somehow messed it up
what i see in putty:
disconnecting.
connecting...
connected
but then nothing more. what i hear is the sound windows makes when you unplug and replug a usb device.
so it looks like the tcpclient call to my service crashes the core somehow?!
but how can this be? all I changed was the url… and the web service seems ok!
Yes I know, that my web service is supposed to return something else than @sebnil’s.
The point is, I don’t want to run my version of “should i bring an umbrella”.
My problem is that I cannot access my web service with a TCPClient. So I was looking around for code where it apparently works. This is why I reused @sebnil’s code.
So when I use that code but with my url I would expect that I would see something like
"W-[000,100,000][144,238,144] - Temp: 10,0°C; Color [DarkGreen] - Condition: FewClouds; Color [LightGreen]"
in putty.
Instead I only see
disconnecting.
connecting...
connected
followed from window’s USB device connection drop / reconnect.
I think you need a “Host: roman-mueller.ch” line in your TCP request. Try adding a client.println() for that.
When I do a reverse lookup on 80.190.254.165, I get a host name of server60.hostfactory.ch. With the advent of edge routers that cache web pages at the edge of networks and multi-name hosting with one physical server being known by many names, the Host: field in the HTTP GET request has become just about required.
Think of it this way–there is one HTTP server on 80.190.254.165 even though that host can serve for many different aliased host names so the Host: field in the request is the only way the HTTP server can know what content to serve.
@bko Agree with what you mentioned. I noticed that missing line so i ask if @kwyjib0 could use back the original without that line and see if it worked.
I think your IIS server is being particularly persnickety. For one thing, yes, you need to include the ‘Host’ header. And for another, your server is returning a 404 (Page not found) error when I use HTTP 1.0, but works fine if I specify HTTP 1.1. So, give this a try:
Technically, the ‘Host’ header is an HTTP 1.1 thing, IIRC. But I’ve never encountered a server before that didn’t honor it even when the GET request specified HTTP 1.0. There may be some setting for this buried somewhere in your server config?
