Is it possible to get the PUBLISHED AT data using particle.subscribe
Does anyone know if it’s possible? I am using IFTTT Do and am looking for a way to make sure each button press is unique. Was thinking of using the published at data if possible.
Not sure if it’s possible with subscribe, but on the device end, you could check the current time and build in a time-out?
Thanks for the suggestion. After doing additional research, it doesn’t look look I will be able to get what I want with subscribe so I will try another route.
