A few years back (~3ish) I was using IRRemote on a few Photons for IR decoding, and then to replicate the IR signal/send for AC units and TVs and such. The firmware was 1.5.0 at the time for the latest per logs.
I recently upgraded a Photon to 2.3.1 and noticed that it went into SOS mode + gave 14 red blinks (heap error).
I tried creating a new simpler firmware (essentially the base example) and that crashed too:
// Include Particle Device OS APIs
#include "Particle.h"
#include <IRremote.h>
// Let Device OS manage the connection to the Particle Cloud
SYSTEM_MODE(AUTOMATIC);
// Show system, cloud connectivity, and application logs over USB
// View logs with CLI using 'particle serial monitor --follow'
SerialLogHandler logHandler(LOG_LEVEL_INFO);
int RECV_PIN = D0;
IRrecv irrecv(RECV_PIN);
decode_results results;
// setup() runs once, when the device is first turned on
// Put initialization like pinMode and begin functions here
irrecv.enableIRIn(); // Start the receiver
// loop() runs over and over again, as quickly as it can execute.
// The core of your code will likely live here.
if (irrecv.decode(&results)) {
//Log.info("Value in HEX: %X", results.value);
Log.info("Test!");
irrecv.resume(); // Receive the next value
// Example: Publish event to cloud every 10 seconds. Uncomment the next 3 lines to try it!
// Log.info("Sending Hello World to the cloud!");
// Particle.publish("Hello world!");
// delay( 10 * 1000 ); // milliseconds and blocking - see docs for more info!
I tried upgrading the firmware to 3x, and same.
I have not followed the releases, did something change in a substantial way that would cause this?
Any help/debug on this would be appreciated.
