Interrupts disabled on Core FW 0.5.3 and later?
I just switched from FW 0.5.2 to 0.5.3 on the Core and noticed that my interrupts are not firing anymore.
Code is more or less straight out of the docs:
setup:
pinMode(D3, INPUT_PULLDOWN);
attachInterrupt(D3, IntHandle3, CHANGE);
code:
void IntHandle3()
{ do stuff }
Works fine with 0.5.2 and earlier. With 0.5.3 and 0.6.0-rc2, the interrupt does not fire. The sub never gets called.
If I add an
interrupts();
to the setup routine, it works again.
Did I miss this ‘feature’ in the release notes?
If so, please update the docs that interrupts have to be explicitly enabled.
Arne
I use interrupts i my code and it works fine with attachInterrupt(). What are you doing in the interrupt function?
I build a very simple setup to reproduce the issue.
Device is a Spark Core.
I when I apply a voltage such as VIN to D3, the blue led should light. If I remove the voltage, it goes off.
Here’s the complete code:
void IntHandle3(void);
volatile int IND3 = 0;
        pinMode(D7, OUTPUT);
        IND3 = digitalRead(D3);
        digitalWrite(D7, IND3);
void IntHandle3() {
    if (IND3 != digitalRead(D3) )
It works fine with FW 0.5.2 and does not work with 0.5.3
I’ll have to dig up one of my Cores to check.
@kennethlimcp, have you tested with a Core?
Update:
I can confirm that I see the same thing with my Core.
@BDub, is this known/intended or should I open an GitHub issue?
Done!
And as mentioned, enabling the interrupts manually will make it work with 0.5.3:
		interrupts();
Yup, opened an issue
I’m glad I found this topic. I ran into the same issue. Now solved with this information. Thanks!
Great to hear!
… so all we need is a fixed firmware :wink:
Agreed…
Bumped into this last night! Thanks for posting this!
