Apologies in advance if this has been covered elsewhere - I just don’t know what terminology to use to search for it:
Where would I find the internal references to system definitions that can be used in my code - things like:
digitalRead(PWR);
analogRead(BATT);
So its the list of PWR and BATT and other definitions I am looking for to see what else is available so I dont have to reinvent the wheel in my code. (For example until I found out about PWR - I had a resistor divider from VSUB to 0V and into an IO pinto do exactly what PWR provides already)
I was just about to link to that too
PWR doesn’t seem to work (Argon or Xenon) - unless I have used incorreclty?
bool checkVUSB()
bool powerState = digitalRead(PWR);
Log.warn(powerState ? "Power ON" : "Power FAIL");
Particle.publish("power_state", powerState ? "on" : "off", PUBLIC);
return powerState;
How are you building?
What do you consider “not working”?
If i have the Argon or Xenon on a ETH featherwing with a LiPo attached. I power the module through the USB port.
Run this code
SYSTEM_THREAD(ENABLED);
DEBUG STUFF
// ApplicationWatchdog wd(30000, System.reset);
SerialLogHandler logHandler(LOG_LEVEL_WARN, // Logging level for non-application messages
{ "app", LOG_LEVEL_ALL } // Logging level for application messages
int led = D7;
const int delayTime = 2500; //
Serial.begin(115200);
waitFor(Serial.isConnected, 30000);
Serial.println(Time.timeStr()); //
Log.info("Started");
pinMode(led, OUTPUT);
// wd.checkin(); // resets the AWDT count
digitalWrite(led, HIGH);
checkBattV();
checkBattC();
checkVUSB();
delay(delayTime);
digitalWrite(led, LOW);
delay(delayTime);
float checkBattV()
float battVoltage = analogRead(BATT) * 0.0011224;
Particle.publish("battery_voltage", String::format("%.2f",battVoltage), PUBLIC);
Log.info("Batt level:%.2fV",battVoltage);
return battVoltage;
bool checkBattC()
bool charging = digitalRead(CHG);
Particle.publish("battery_charging", charging ? "yes" : "no", PUBLIC);
Log.info("Batt %s charging", charging ? "is" : "not");
return charging;
bool checkVUSB()
return powerState;
Power state never changes:
With USB plugged in the particle console shows power_state off (every 5s)
Unplug usb power console still shows power_state off (every 5s)
Have you set pinMode(PWR, INPUT) - I can’t seem to find that instruction?
I think unlike the STM32 devices the default on nRF is not INPUT but something like “not-set”.
Ping! - working! Sometime its so easy to miss the obvious!
What is interesting is that on the Xenon with no battery connected is still shows CHG is high - but I have seen thread about this elsewhere …
That’s because CHG is active low (it’s actually /CHG)
cool - help me understand how I would have seen that in the link to the source files above ?
Not directly from the device OS sources but from the HW schematic and/or the forum
https://docs.particle.io/datasheets/mesh/xenon-datasheet/#power-1
I have been monitoring the digitalRead(CHG) for the battery is charging along with digitalRead(PWR).
For CHG pin 0 = charging and 1 = not charging. For PWR 0 = battery, 1 = USB powered.
When battery powered the CHG will show as 0 (charging)? Is there a reason for this - as it appears to be a fault/bug?
