Integration with Home Assistant?
Is there any interest in the kind of integration Particle has had with other web companies like IFTTT ? At the moment I’m using one of my Photons as a “Rosetta Stone” - it converts between Particle Pub/Sub to MQTT. It would be cool if I didn’t need to do this.
Cheers!
I have several particles connected to Home Assistant via mqtt. Alarm system, garage door opener, and sofa controler. I prefer not requiring the cloud for connectivity to a local server. MQTT works really well using the mqtt library.
I like the idea of a sofa controller! Tell me moooore!
I would use the MQTT library exclusively but I’m not sure my old Spark Cores are stable on the MQTT library but my Photons cope fine with it.
