So I’m compiling locally (on windows) and I’m having some issues porting a library I’m working on.
Here’s what I have done:
- Added both my libraries to the
librariespath - Added both my ePaper library and a SD library to the makefile using:
INCLUDE_DIRS += $(LIB_CORE_LIBRARIES_PATH)Small_ePaper_Shield
INCLUDE_DIRS += $(LIB_CORE_LIBRARIES_PATH)SD
I couldn’t find another way to actually include the libraries. Surely there is a better way that doesn’t require editing the makefile?
- Added my code to application.cpp. A snippet is below
Code:
#include "application.h"
#include "ePaper.h"
#include <SPI.h>
#include <SD.h>
#include "GT20L16_drive.h"
#define EPD_SIZE EPD_2_7
int x;
char tmpTemp[15];
ePaper EPAPER;
sd_epaper eSD;
GT20L16_drive GT20L16;
SYSTEM_MODE(MANUAL);
while(!Serial.available());
Serial.println("Program Start");
Serial.println("This is a test!");
EPAPER.begin(EPD_SIZE);
EPAPER.setDirection(DIRNORMAL);
eSD.begin(EPD_SIZE);
GT20L16.begin();
Serial.println("Setup end");
I end up with several errors like the below:
```./obj/src/application.o: In function setup': E:\Spark\Spark\firmware\build/../src/application.cpp:68: undefined reference toePaper::begin(EPD_size)‘
E:\Spark\Spark\firmware\build/…/src/application.cpp:69: undefined reference to ePaper::setDirection(EPD_DIR)' E:\Spark\Spark\firmware\build/../src/application.cpp:70: undefined reference tosd_epaper::begin(EPD_size)’
Any idea what's going on? The functions mentioned in "undefined" reference are there. In fact, NetBeans will autocomplete for them!
Help me, @BDub, you are (almost) my only hope! (perhaps @mdma?)
Harrison
Note: I originally didn't have the following references:
ePaper EPAPER;
sd_epaper eSD;
because they weren't needed in the Arduino enviroment. Something to do with the follow line (and similar) in ePaper.h:
extern ePaper EPAPER;
but that doesn't appear to work in the Spark build enviroment
