Is there a way to add library from github?
Fuzzy Library: https://github.com/zerokol/eFLL
That library would probably require some porting but definetly a restructure to fit the library structure used by Particle and Arduino.
I would suggest using Workbench/VSC if you are going to port it to Particle.
