All
I’ve got a ili9341 (2.8’ tft spi 240x320) screen I acquired, will the photon run this? I don’t need the touch screen side of this running just the display. cheers
link to screen below
All
@Codeman, any Particle device will work with that display, including the Photon.
Thanks, are there any examples out there?, can’t for the life of me get this working, all the samples i use for ili9341 don’t seem to work so does it use ili9341 ?
I’m not a professional programmer so am reliant on examples for this.
Thanks in Advance
@Codeman, which ili9341 library are you using and how is your display connected?
@peekay123 - ive been at this days and ive tried just about every library ive ready about, im currently on Adafriut_ili9341 but this always seems to point to the featherwing version of this screen (2.8 TFT Touch Shield for Arduino with Resistive Touch Screen : ID 1651 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits)
And ive tried various connections according to different libraries, sorry to be vague , ive completely disconnected it now to start from fresh incase ive missed something
@Codeman, if you are using the Featherwing version then I am not sure how you are using with with a Photon. Can you explain?
