Hi everybody,
this is my first post here.
I have been digging in the Particle community, but I could not find anything relevant to my problem.
I have developed a firmware that keeps the Core into deep sleep most of the time.
Whenever it wakes up, it connects to the cloud (SEMI_AUTOMATIC mode), subscribes to 1 SSE channel (always the same one) and publishes an event.
I have also created an IFTTT recipe that waits for such event and sends back to my device an acknowledge event (to the SSE channel my device subscribes during setup).
I am using my browser (Chrome) to see the events published by my device and it works fine. All the publish() performed by my Core are received successfully and in within a second or two.
My problem is that sometimes I need to send the acknowledge event twice to my device via IFTTT/DoButton before my device receives just one of them.
Some other times by sending the event twice (double DoButton or IFTTTrecipe+DoButton) will make my device receive both events and with a shorter delay compared to the successful single acknowledge event case.
I have also tested my firmware bypassing IFTTT and using the app DoButton to send events to my device and it works much better. Just in very few cases I had to “push the button” twice. Usually my device receives the ack event and reacts in a couple of seconds.
When the firmware publishes the event triggering the IFTTT recipe, my browser prints an event “ifttt-trigger-event-check” about 5-10 seconds after the triggering event. It is not generated by the Core but by IFTTT, right?
In addition can anybody clarify what kind of delays should I expect when waiting for a message sent by IFTTT recipe or DoButton?
ps. My IFTTT recipe and DoButton are based just on Particle/Spark’s ingredients!
Thank you very much
Marco
