We are trying our firmware on 2.0.1 from 1.5.2 on a boron and are having some issues reading data from our FRAM.
We are consistently seeing a “2: START bit generation timeout” when running the unmodified code on 2.0.1 where it works fine on 1.5.2.
Doing a Logic Analyse we can see that the i2c bus is somewhat slower in getting to start and stop bits on 2.0.1 vs 1.5.2
This is 1.5.2 where the start bit and stop bits are short 30uS as expected
But on 2.0.1 these are nearly 3times slower
What I’m confused about is how these timing could be so different between system firmware versions where the I2C should be Hardware powered. Unless I am mistaken and particle actually has a soft I2C Implementation?
I’m now a little stumped as to how to proceed to debugging and fixing this issue. Any sugguestions?
