i2c connection: Arduino 3.3V <-> Spark Core
Dear All,
I have an homemade arduino with a Atmega168-20PU (running at 3.3V) which I would like to connect via i2c to my Spark Core (as master).
This is the connection I understood I should do:
where the value of resistors “R” can be any between 1.5k and 10k (http://docs.spark.io/firmware/#communication-wire).
Is the connection correct and what is the suggested value for R?
Thank you,
dk
@d82k, that is the correct configuration. A good resistor value is 4.7K ohms. Which device will be slave and which is master?
Thank you @peekay123 for your answer.
The Spark will be the master.
