I need some advice about Hall effect sensor compatibility with Argon
I am new to IoT and electronics. I’ve purchased these Hall effect sensors that I am hoping to use for a level control device for an industrial application (prototype).
Does anyone know if these Hall sensors will function with the Argon?
Thanks!!
CANADUINO 5 x A3144 Hall Effect Sensor Switch - 4.5 to 24V Power Supply - Open Collector Output 25mA - TO-92 Package
Product description
These Hall-effect switches are monolithic integrated circuits with tighter magnetic specifications, designed to operate continuously over extended temperatures to +150°C, and are more stable with both temperature and supply voltage changes.
The unipolar switching characteristic makes these devices ideal for use with a simple bar or rod magnet.
Each device includes a voltage regulator for operation with supply voltages of 4.5 to 24 volts, reverse battery protection diode, quadratic Hall-voltage generator, temperature compensation circuitry, smallsignal amplifier, Schmitt trigger, and an open-collector output to sink up to 25 mA.
With suitable output pull up (for example 10k), they can be used with bipolar or CMOS logic circuits like micro controllers.
Yes, just power the Hall effect sensor with 5V and define the sensor pin as INPUT_PULLUP.
Thanks Daniel!
Cheers
Chris
