Okay, so after some hunting and digging, I found a piece of HTTP Post code that uses the HTTP Client library. I was able to get the code to post successfuly 1-2 times but more often than not, the HTTP response status is:
Last Reset Reason : -1…then shortly after that on the console I get spark/device/diagnostic/update.
The code I am using is the following:
//Serial.begin(9600);
while (!WiFi.ready())
request.ip = remoteIP;
request.port = 8699;
request.path = "/measures/768768000";
Particle.publish("SETUP","We have an IP",60,PRIVATE);
Particle.publish("Loop","Start of Loop",60,PRIVATE);
request.body = "{\"capabilityAlternateId\":\"1\",\"sensorAlternateId\":\"24252627\",\"measures\":[[\"15\"]] }";
http.post(request, response, headers);
sprintf(resstatus,"Response Status: %",response.status);
Particle.publish("Loop",resstatus,60,PRIVATE);
delay(2000);
