Hello I’m working on a project where I would like to incorporate a capacitive touch sensor to toggle between brightness(low,medium,high,off). I’m not sure how to start. Any recommendations?
Thank You
Tameim Amon
Thank You
Tameim Amon
Have you got some code for the cap touch sensor to start with?
With that the “toggle” would be simple
enum BRIGHTNESSLEVEL
{ brOFF = 0
, brLOW
, brMED
, brHIGH
BRIGHTNESSLEVEL br = brOFF;
BRIGHTNESSLEVEL levelUp() {
br++;
if (br > brHIGH) br = brOFF;
return br;
Hi Tameim,
If I needed to do something like that, I would get some inspiration here:
and why not, here as well:
Cheers
Gustavo.
scroll down to the section WORKING WITH CAPACITIVE TOUCH
if (showRainbow)
rainbow(20);
else
for (int i = 0; i < CRICKIT_NUM_TOUCH; i++)
{ // check each touch input
uint16_t val = crickit.touchRead(i); // read the touch input
if (val > CAPTOUCH_THRESH)
{ // if the value read is > the threshold
switch (i)
case 0:
setAllPixels(255, 0, 0); //RED
break;
case 1:
setAllPixels(0, 255, 0); //GREEN
break;
case 2:
setAllPixels(0, 0, 255); //BLUE
break;
case 3:
setAllPixels(122, 123, 123); //WHITE
break;
delay(100);
