I’ve uploaded some code to my spark which is working fine. However I want to be able to read the analog values I’m getting of my FSR . I’ve downloaded Putty, and it only seems to detect my spark core when it’s in listening mode, and when that’s the case the code isn’t running so I don’t get any values.
That is an often asked question on this forum and it is always answered the same:
You have to use Serial.begin(115200); (or any other baud rate) in your setup().
Please use the search function - it does work ![]()
e.g.
Hi @Kevinruder
One of the weird things about USB devices is that being connected and drawing power from USB does not trigger a software driver to be loaded for a device on a PC etc. This device has to be enumerated in USB-speak before the driver is loaded and the device becomes available.
On Spark that means that until you execute the line Serial.begin(9600); your Spark core does not look like a USB device to the PC. After that line it is enumerated and becomes available. A good strategy on PCs is to wait for a keypress over the serial port before proceeding with the debugging, but you should remember you core will look “hung” until you press a key:
while(!Serial.available()) {
SPARK_WLAN_Loop();
Serial.println("connecting...");
On Macs and Linux you don’t have to wait–you can just connect after the core boots up.
Oh its working now
thank for the help !
