I assume this is meant for Particle Dev/Particle CLI users, who have been stuck with throwing everything into the same directory.
I looked into the commit assosicated with this enhancement and see that when you have a “src” directory, it then calls this an “extended” application environment; this includes the sibling “lib” directory and subfolders.
Does the .ino go in src/?
How do I #include the libs in lib from within my .ino?
Let’s say I want to use the Blynk library, located at lib/blynk/blynk.h.
Do I include by:
../lib/blynk/blynk.h (relative to the .ino in src)
lib/blynk/blynk.h (relative to the project root)
blynk/blynk.h (like Particle Build, relative to the lib root)
something else?
I tried to play around with this since it’s something I’ve been looking forward to for a while, but can’t get any configuration to build within Particle Dev (haven’t tried CLI yet).
These are changes required for the new library system to easier import libs across all Particle IDEs and get closer to the pseudo standard set by Arduino IDE.
There will be a seperate announcment once “Libraries v2” goes live.
I spoke too soon - this arrangement above compiles but produces a completely unusable binary. Am I missing something? Can I use this “feature” before you guys fully release the “Libraries v2” shenanigans?
