How to use analogWrite to regulate a led?
Hello,
I want to send a value to the cloud via a mobile app and this value I want it’s going to be the analogWrite value of a led. I want start with the led at maximum.
I did that but i think it’s not well done. A function can’t recive an int, must recibe a string, can it?
How can I do that?
Thank you so much, and sorry for my mistakes.
    int led2 = A5;
    pinMode(led2,
    analogWrite(led,256);
    Particl.function("led2",ledToggleAnalog);
    int ledToggleAnalog(int value) {
    analogWrite(led2,value);
    return 1;
I'm not sure what this is but pinMode() is used to set the mode of the specified pin, for example INPUT or OUTPUT. Also, analogWrite(), by default, takes a value between 0 and 255. Your code should look like this:
pinMode(led2, OUTPUT);
analogWrite(led2,255);   // Full ON LED
Particle.function(), is passed a String object so your callback function definition needs to look like:
int ledToggleAnalog(String value) {
Assuming you pass a numerical value (between 0 and 255) while calling the Particle.function(), then your code needs to convert the String to an integer value:
    // Convert the ascii representation (string) of the value to an integer
    int val = value.toInt();
    if (val < 0 || val > 255)  //check if within acceptable range
      return -1;               // return -1 to indicate error
    analogWrite(led2,val);
    return 1;
Make sure to add a current limiting resistor (150 - 1K ohms) in series with your LED on pin A5 or you may damage the Photon GPIO pin. Also note that LED brightness will not be linear over the PWM range (0-255) of the analog output. I highly recommend you read the documentation on the various functions you are using.
Below the WebIDE you will find example sketches - the example number 2 fits perfectly for your purpose: Web-Controlled LED - recommendation for transparency.
sorry! It was:
pinMode(led2,OUTPUT);
thanks for the reply, now I’m going to study it well!
Yes, but it's with digital not analog. Thanks.
@fcabana, in the Arduino world, the digital PWM output is considered “analog” (loosely said). In electronics, true analog is obtained via a DAC (digital to analog).
