In the firmware page is says that I can upgrade it OTA but I cannot find the procedure. How can I do it?
Hi @bigakis - visit our web IDE to program the Core over the air:
Thx Zach. I finally used dfu to install the new firmware.
If would be great if we could upgrade OTA using a command-line built .bin file. Save all the messing about with dfu.
Thanks so much. I tried searching spark core flash OTA, but didn’t find that reference.
We’re also working on a command line tool that will use the api and should make this easy as well
After browsing the code from github, I realized that when the new firmware is uploaded, the system compiles the last version of the whole firmware plus your code.
So every time a new firmware is uploaded via the website the core firmware is also updated to the last version on the spark.io site.
Only the bootloader is not affected.
Hi @bigakis,
Ahh, yes! Sorry about any confusion there.
Every build is done on-top of core-firmware and the other core libraries, so your code gets the benefit of any improvements there automatically.
If you really want to change the bootloader you can, but you need a programmer-shield to do it. We intentionally don’t change that very often since it needs to be so stable / reliable.
David
