How to toggle relay for 1s?
hello, I need some help please
I need to add to my firm - see below, a momentary instance to a relay ( 1 sec)
can you please be kind and add it to my firm?
thanks in advance
#include "RelayShield.h"
// Create an instance of the RelayShield library, so we have something to talk to
RelayShield myRelays;
int relayOn(String command);
int relayOff(String command);
    //.begin() sets up a couple of things and is necessary to use the rest of the functions
    myRelays.begin();
    Particle.function("relayOn", relayOn);
    Particle.function("relayOff", relayOff);
    // Nothing needed here, functions will just run when called
int relayOn(String command){
    // Ritual incantation to convert String into Int
    char inputStr[64];
    command.toCharArray(inputStr,64);
    int i = atoi(inputStr);
    // Turn the desired relay on
    myRelays.on(i);
    // Respond
    return 1;
int relayOff(String command){
    char inputStr[64];
    // Turn the desired relay off
    myRelays.off(i);
    // Respond
    return 1;
I’ve cleaned up your code a bit. What exactly do you mean by “a momentary instance to a relay”? Do you want to delay for a second before turning a relay on or off?
int relayOn(const char* args);
int relayOff(const char* args);
        myRelays.begin();
int relayOn(const char* args) {
        // Char array to int
        int i = atoi(args);
        myRelays.on(i);
        // Respond
        return 1;
int relayOff(const char* args) {
        int i = atoi(args);
        myRelays.off(i);
        // Respond
        return 1;
thanks @nrobinson2000
Yes, " Do you want to delay for a second before turning a relay on or off?"
You can put delay(1000); into relayOn() and relayOff()
yes but that case the relay will only have a delay? or i can keep on off option?
were is the line will be located in my firm?
        myRelays.begin();
        int i = atoi(args);
        myRelays.on(i);
        delay(1000); // HERE IS THE DELAY
        // Respond
        return 1;
        int i = atoi(args);
        myRelays.off(i);
        // Respond
        return 1;
thanks
the on / off works fine
what is the on with delay command?
I think you want to clarify a bit better what you are after.
Do you want a function which
  • toggles the current state for one second and then return to the original state, or
  • switches ON for one second and back to OFF, or
  • switches OFF for one second and than back ON, or
  • all of that
However, this is not the most complex problem, so when you want to get into this kind of stuff, you should try to understand what and how your existing code does already and from that plus the info you got given by @nrobinson2000 you should be able invest some of your own brain power into the project to come up with a solution.
what I need is
“switch ON for one second and back to OFF”
thanks
You know how to switch on.
You know how to delay exection for 1 second.
You know how to switch off.
So you only need to put all three “tasks” together into one function.
thanks, i will look into it
