How to read Serial without SparkCloud
I would like to connect a sensor to my SparkCore, load the firmware from the cloud as usually, but while the app is running in the core I would like to see my sensor data in realtime by reading the usb serial in my PC.
This way Im able to debug my app faster… since I don’t have to make http requests in order to analyse data.
omarojo, you can just Serial.print() to the port! Here is the information in the Spark documentation. Let me know if you need help after reading that. :slight_smile:
You r totally right… my bad, I actually read that section before. :smile:
