I want to generate a square pulses using photon. Can any one tell me how to achieve that?
I tried this code but its showing a error
expected constructor, destructor, or type conversion before ‘(’ token
I don’t have any idea regarding this please help me,
That sounds like you have a syntax error in your code. You should show us the code that gave that error.
Just by looking at the error I’d expect your code to look like this
tone(D0, 1000, 10);
// whatever ...
// whatever ...
But if you copied the actual usage sample it should work
// EXAMPLE USAGE
// Plays a melody - Connect small speaker to analog pin A0
int speakerPin = A0;
// notes in the melody:
int melody[] = {1908,2551,2551,2273,2551,0,2024,1908}; //C4,G3,G3,A3,G3,0,B3,C4
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {4,8,8,4,4,4,4,4 };
// iterate over the notes of the melody:
for (int thisNote = 0; thisNote < 8; thisNote++) {
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000/noteDurations[thisNote];
tone(speakerPin, melody[thisNote],noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(speakerPin);
Just plonking a function call in the global declaration section will never work
Functional calls need to be placed inside a function.
