I am trying to write Mario Theme song for my Photon. I know how to use tone and noTone butit is very tedious and more lines of codes than on C++.
On photon
tone(b,330);
delay(100);
noTone(b);
delay(100);
On C++
Beep (330,100);Sleep(100);
Is there any other library on Particle Photon that I can use so that I can write less number of codes ?
One option is the [InternetButton library] (https://build.particle.io/libs/55e0a4256b6e3275580009ce/tab/1_Blink_An_LED.cpp) example #8 which shows how to play a song with a string containing note names and durations.
The relevant code is copied into this post, which is much easier to copy and paste from.
KyleG
4
Thanks for your help @rickkas7!
