How to fetch data from an API
Hey guys
Im new to API so bear we with me.
Im trying get data from a api website which outputs in JSON format. I dont know where to start haha. what functions do i use to fetch data from the website and display it over serial.
You could use a webhook:
https://docs.particle.io/guide/tools-and-features/webhooks/
Will this let me call a GET function?
Yes.
ok thanks, ill look into this… is there a piece code that someone has written to call a GET funciton?? sorry completely new to this kinda stuff
With or without using a webhook?
any?
Let’s do it with a webhook.
What API do you want to get data from?
my work has this company API. currently im calling the urls using Postman.
Ok, no problem.
Can you make a webhook from within the Particle Console?
https://console.particle.io/integrations
i just wana call this url with the photon. https://example.sada/api/sda/recipe?api_token=blahblahla
Try making a webhook like this:
ok ill give it a shot, thanks
It doesnt post anything on console
Maybe you could reduce the delay?
OMG thanks dude!
is there a different way to to trigger the integration?
i want to store that data into a string so i can use the info. Thanks
Do you want the photon to get the full JSON or just certain part(s)?
