How to control multiple stepper motors separately with photon
hello,
I have 4 x (28byj-48) stepper motors, I’m trying to connect them to particle photon and control each one separately.
Whats the best way to do that?
Using a stepper controller (e.g. A4988)
These ususally only take two control lines (direction and step) and hence you should be good with the possible 18 GPIOs available on a Photon.
You could even get a fancy quad-stepper-driver like this
https://www.sparkfun.com/products/retired/10507
For a lower amount of steppers you will find here a first intro,@hasanals:
Is their any other stepper controllers similar to this? This one is not available in any online shop.
Whaaaat, A4988 isn’t available? These are by far the most common ones - I’d look for a different online shop.
But sure there are plenty others
LMGTFY
… Google found this for me: https://www.robotshop.com/en/stepper-motor-controllers.html
… or for quad driver https://www.google.at/search?q=quad+stepper+driver+board&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwjW59qZ_sveAhVIBywKHS8wD0MQsAR6BAgDEAE&biw=1303&bih=811
