Can someone tell me how to clear the Terminal window in Particle Workbench? (Using Ctrl - Shift P commands) I use Ctrl Shift P (Serial Monitor) to start…but then when I make code changes I want to clear it for a fresh start
Detach Terminal doesn’t seem to clear it…
Thank you
Have you tried entering clear?
If you are using the serial monitor and not using the stay connected option (–follow), then use clear as ScruffR said, or Ctrl-L to clear the screen. Then use Up Arrow or Ctrl-P to run the command again to reconnect.
If you are using the stay connected option, then you need to Ctrl-C out of the serial monitor, then do the steps to clear and restart it.
