How to change the Core LED color?
Hi all,
Yesterday I got my spark core and it all worked fine. I want to change or off the Core RGB LED color when my application running, because of the Core RGB LED light is so bright. I think maybe edit and re-build spark core firmware it’s could be, but I want to use without rebuild firmware.
Any good idea to do it?
Thank you.
Hi @hirotakaster,
We added functions to do this recently, you can take control of the RGB led using:
-- take control of the LED
RGB.control(true);
-- resume normal operation
RGB.control(false);
// red, green, blue, 0-255
RGB.color(0, 0, 0);
Hi @Dave ,
Thank you, that’s nice!! I can control the RGB led :smile:
This has now been documented in the firmware docs:
http://docs.spark.io/#/firmware/libraries-rgb
Hi @zach
Thank you for letting me know!!
