How much bandwith does Particle Publish use?
How much bandwidth does the Particle Photon use? Let’s assume the Particle Photon is publishing an event once a second (the maximum rate in which Particle’s service allows events). How much bandwidth would the Particle Photon use per hour, day, week month, year et cetera…?
This is for the electrons that we have.
yea. i’m seeing almost 5MB in the past day, with only publishing once a minute.
It wasn’t like that last week. Does cellular connection/reconnection contribute alot? we haven’t done any otas to these devices either.
@elevatorguy, are you deep sleeping or turning off and on the cellular radio often?
I was talking about the Photon and not the Electron.
@Greg123 Sorry about that.
@peekay123 moved discussion over to Recent electron data usage
That’s fine
In terms of the electron, that is normally connected to the cloud, without sleep. But does not publish anything, except an event once a day with one character as e name and no parameters… I am seeing high consumption of data.
I am sure the event is only publishing once a day. I am seeing about .1 MB per day. With a max of two events.
Any clues? Am I doing something wrong or is this expected?
