How do I import a INA260 library from Arduino?
I’ve seen other posts about importing libraries from other sources but I’m not sure if the process is the same for each source and each device type. There’s a library for the arduino INA216 already in the particle system but I have an INA260. I was looking to see if there was an easy way to import the library into the particle universe so I could use it with my particle?
Hi Lavell
maybe this can help?
https://docs.particle.io/tutorials/device-os/libraries/#contributing-libraries
cheers
Gustavo.
