How can we use Particle.function from within a class?
I want this:
MyClass::begin(){
      Particle.function("myfunction",doIt);
int MyClass::doIt(String str){}
I tried:
1.  Particle.function("myfunction",MyClass::doIt);
2.  Particle.function("myfunction",this->doIt);
Is it is possible at all, and if, how :flushed:
Compared to a regular function pointer (which is a single pointer) a class function is actually 2 pointers - the function itself and the β€˜this’ pointer. The simplest way to encapsulate both of these so to use a lambda expression.
class MyClass
	void begin()
		Particle.function("myfunc", [this](const String& s)->int{return doIt(s); });
	int doIt(String arg)
		return 0;
Perfect, works, tnx
