Function pointers work with spark compile but not particle compile
I have the following function declaration that compiled and ran successfully on the spark core using spark compile:
     void download(HttpDownloadRequest &aRequest, HttpDownloadResponse &aResponse, HttpDownloadHeader headers[], void(*callback)(byte*, int, void*), void* callbackParam);
The pentultimate param is a c++ function pointer. When I compile with particle compile for my photon, I get this:
HttpDownload.h:62:128: error: expected ‘,’ or ‘…’ before ‘(’ token
Did the compiler change? Are function pointers no longer supported?
Ryan
C99/C++11, and with it, function pointers, is still fully supported.
The code that you pasted looks fine. And I can paste this into the WebIDE
class HttpDownloadRequest;
class HttpDownloadResponse;
class HttpDownloadHeader;
Which compiles fine. So it would seem the error lies somewhere else. If you can paste a link to the code that I can try I’m happy to help you investigate other possible causes of the error.
Weird.
‘particle compile core’ compiles the project correctly.
‘particle compile photon’ fails.
Let me take a look at the source with fresh eyes in the morning and see if I can see anything weird.
Ryan
The problem above was caused by my code not including application.h and using the “byte” typedef - not required on the core, but needed on the photon, apparently :smile:
Now I have problems with PIN_MAP, but there are other threads I need to read through on that. I’m guessing the libraries I’m using aren’t updated yet.
Consider this one resolved.
Ryan
@rsteckler, you are correct regarding the PIN_MAP issue. The upcoming firmware release will include a set of fast IO functions that will replace the “direct” PIN_MAP reference with inline functions. This will also make its way to the new Core firmware released that is planned. So this will allow for a standardized way to do fast IO on any existing and future Particle platforms :smile:
BTW - a bit write with the new fast IO code takes about 30 nanoseconds :stuck_out_tongue:
Thanks, @peekay123 .
For now, is there a simple way to get the old PIN_MAP code working? It’s being used in the sd2card library I’m using.
Ryan
Yes, in the meantime you can use
#if defined(PLATFORM_ID)
#include "pinmap_hal.h"
static STM32_Pin_Info* PIN_MAP = HAL_Pin_Map();
#endif
Hmm. I get this:
Sd2Card.cpp:768:40: error: ‘struct GPIO_TypeDef’ has no member named 'BSRR’
PIN_MAP[mosiPin_].gpio_peripheral->BSRR = PIN_MAP[mosiPin_].gpio_pin; // Data High
Sd2Card.cpp:770:40: error: ‘struct GPIO_TypeDef’ has no member named 'BRR’
PIN_MAP[mosiPin_].gpio_peripheral->BRR = PIN_MAP[mosiPin_].gpio_pin; // Data Low
Sd2Card.cpp:772:40: error: ‘struct GPIO_TypeDef’ has no member named 'BSRR’
PIN_MAP[clockPin_].gpio_peripheral->BSRR = PIN_MAP[clockPin_].gpio_pin; // Clock High
Sd2Card.cpp:778:40: error: ‘struct GPIO_TypeDef’ has no member named 'BRR’
PIN_MAP[clockPin_].gpio_peripheral->BRR = PIN_MAP[clockPin_].gpio_pin; // Clock Low
Nevermind. Got it :smile:
The answer is here: https://github.com/sazp96/SparkCore-SD/commit/2a077274a96738de561ac07db36352a0b4f74b10
