How can I build a monolithic firmware?
Hi all,
I'm trying to build my own device os for Boron LTE in order to enable system debug (details here). I have downloaded device os source code and I run this command from modules folder:
make PLATFORM=boron all
After this, I flash
build/target/system-part1/platform-13-m/system-part1.bin
and
/build/target/user-part/platform-13-m/user-part.bin
But I want to build a monolithic firmware. How can I do that?
And what is the application file I have to modify in order to code the application?
Thank you,
Manuel Montenegro
From main (not modules):
make PLATFORM=boron MODULAR=n all APPDIR=/path/to/your/app/dir
Usually you’d specify the source directory using APPDIR. The monolithic binary will go into the target subdirectory in that directory.
Thank you for your response.
But I can't do this work. From device-os/main I run this:
make PLATFORM=boron MODULAR=n all APPDIR=/Users/manuel/ParticleDesarrollo/build
But I get this error:
/Library/Developer/CommandLineTools/usr/bin/make -C ../newlib_nano
make[1]: Nothing to be done for `all'.
/Library/Developer/CommandLineTools/usr/bin/make -C ../user
build.mk:65: *** "No sources found in /Users/manuel/ParticleDesarrollo/build/". Stop.
make: *** [user] Error 2
Sorry, I didn’t understand what is APPDIR. Now it’s building…
Now it’s working. Thank you,
Manuel Montenegro
