I have found it sometimes useful to recycle power to my Patrticle devices, like once every 24 hours. Currently, I am doing it with an external timer. I know that I can reset the board with the System.reset command but as previous posts have indicated, this never “really” resets everything.
Not knowing enough about electronics, is there a way a Xenon can recycle power to itself, using for example a relay feather only? My thought is powering the Xenon using the NC output of the relay powered externally by 5V, then using the Xenon to set the relay high by its pin, which would cause immediate but temporary loss of power to it.
I’d rather (re)ask the question why is it happening.
As I said, since there is only one µC on the device System.reset() should do the same thing to it as pulling the RST line low.
Since the OS internally must be communicating with the micro and its onboard radio, System.reset should reset the radio first before it resets the board registers …
