Help with web ploting javascript
Hi guys, I’m currently doing a personal project to monitor the temperature of the room I am, and plot it via web. I’m using a Particle photon micro controller to gather the temperature and send it via JSON. I’m trying to plot it with “plot.ly” and when I’m trying to change the default value to my variable, it doesn’t work. I already plot it using high-charts and a google gauges.
A little background, I don’t have knowledge programming on javascript or using JSON.
This is my code:
var accessToken = "xxxxxxxx"; //not display for security
var deviceID = "xxxxx" ////not display for security
var url_temp = "https://api.particle.io/v1/devices/" + deviceID + "/Temperatura";
var tiempo = 50;
var tiempo_r= 500;
//TEMPERATURA
function callback_temp(data, status){
  if (status == "success") {
    temp = parseFloat(data.result);
    setTimeout(getReading, tiempo_r);
  else {
    alert("There was a problem");
function getReading_temp(){
    $.get(url_temp, {access_token: accessToken}, callback_temp);
var data = [
    domain: { x: [0, 1], y: [0, 1] },
    value: temp,
    title: { text: "Temperature" },
    type: "indicator",
    mode: "gauge+number"
var layout = { width: 600, height: 500, margin: { t: 0, b: 0 } };
Plotly.newPlot('myDiv', data, layout);
First image: Attribute “value:temp” the graph stops rendering
Second image: Attribute “value:250”
var data = [
    value: 250,
    type: "indicator",
Any ideas on how to correct it?
ps:I didn’t include the js for the other 2 graps because they work ok, no need to change them.
You got several screenshots but we have no context what you want to see vs. what you see.
There is also one “stray” screenshot which shows a value of 450 but nothing to compare that with.
BTW, you have 450 - which obviously relates to speed - but then you want to know about temp - how do those two things relate to oneanother?
And you should have a global temp variable defined before using it in callback_temp to ensure the received value is not only living inside that function and vanish after the function is finished.
You also call g.refresh(temp) but we don’t know how this is implemented as we don’t know what kind of object g is nor what refresh() does.
Hi ScruffR, thank you for taking the time to look at it, let me try to explain myself better.
What I want to see is the reading from my photon's temp variable on the right upper graph, as I do on both lower graphs that display this value.
When I change the value of the attribute "value" on the graph for my variable temp, the graph stops rendering as the first image. When I put a random number(as the second picture) it shows it.
The title speed is just the graph demo's name, it has nothing to do with what I want to show. I'll try to correct this on the first post to ensure it is clear.
with Particle official approach works like charm :slight_smile: (personally I don’t like JQUERY)
<html>
  <head>
        <meta charset="utf-8"/>
  <body>
 <div id="chart_div" ></div>
 <div id="chart_div2" ></div>
  </body>
      <script src="https://cdn.plot.ly/plotly-latest.min.js"></script>
      <script type="text/javascript" src="https://cdn.jsdelivr.net/npm/particle-api-js@8/dist/particle.min.js">
        </script>
   <script type="text/javascript">
      var dane = 0;
      var particle = new Particle();
      var layout2 = { width: 600, height: 500, margin: { t: 0, b: 0 } };
     var token1 = "YOUR_TOKEN";
     var devID = "YOUR_DEV_ID";
         function get_data(){
         particle.getVariable({ deviceId: devID , name: 'status', auth: token1 }).then(
            function(data) {
               console.log('Device variable retrieved successfully:', JSON.parse(data.body.result));
               dane = JSON.parse(data.body.result);
            function(err) {
               console.log('An error occurred while getting attrs:', err);
        setInterval(function() {
          get_data();
          if(dane != 0){
            console.log('temp_boron', dane.temperature_c.toFixed(2));
            console.log('battery_v', dane.bat.toFixed(2) );
            plot();
        }, 2000);
   function plot(){
            var data = [
                value: dane.temperature_c,
                type: "indicator",
             Plotly.newPlot('chart_div', data, layout);
          var data2 = [
             value: dane.pressure_pKa,
             title: { text: "pressure" },
             type: "indicator",
             Plotly.newPlot('chart_div2', data2, layout2);
    </script>
  </head>
</html>
I guessing with your approach, you have to call “var data” and Plotly.newPlot every time you want to refresh your data so try to modify your js. some like this:
<html>
  <head>
  <body>
  </body>
      <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
var accessToken = "YOUR_TOKEN"; //not display for security
var deviceID = "YOUR_DEV_ID" ////not display for security
var url_temp = "https://api.particle.io/v1/devices/" + deviceID + "/status";
var tiempo = 50;
var tiempo_r= 1000;
//TEMPERATURA
    var temp = JSON.parse(data.result);
    //console.log("temp", temp);
    //var temperature = temp.temperature_c;
    //console.log("tempperature", temperature);
    //setTimeout(getReading, tiempo_r);
    plot(temp.temperature_c);
  else {
    console.log("There was a problem");
function plot(res){
   var data = [
    value: res,
    type: "indicator",
getReading_temp();
}, tiempo_r);
    </script>
  </head>
</html>
Also setTimeout(getReading, tiempo_r) will never be called as getReading does not exist and is inside callback_temp function which is also not called nowhere you have to use setInterval() instead of setTimeout() and call getReading_temp() over and over and over…
I tested both solutions they are working fine :slight_smile:
Your Modified js.
With Particle object.
Hi dreamER, thank you for your respond!
I copied your code with my token and device id, but didn’t work. So I did try to adapt my code to yours, making some changes.
This is my whole .js code
var accessToken = "xxx";
var deviceID = "xxx"
var layout = { width: 300, height: 300, margin: { t: 0, b: 0 } };
//TEMPERATURA
  else {
// GOOGLE GAUGE
google.charts.load('current', {'packages':['gauge']});
google.charts.setOnLoadCallback(temperatura);
  //MEDIDOR DE TEMPERATURA
	function temperatura() {
        var data = google.visualization.arrayToDataTable([
          ['Label', 'Value'],
          ['Temperatura', 0],
        var options = {
          width: 250, height: 250,
          yellowFrom:30, yellowTo: 40,
          redFrom: 40, redTo: 50,
          minorTicks: 5,
          min:0,
          max:50,
        var chart = new google.visualization.Gauge(document.getElementById('chart_temp'));
		      getReading_temp();
		      chart.draw(data, options);
          data.setValue(0, 1, temp);
        }, 1000);
//----------------------------high-charts graph
var gaugeOptions = {
    chart: {
        type: 'solidgauge'
    title: null,
    pane: {
        center: ['50%', '85%'],
        startAngle: -90,
        endAngle: 90,
        background: {
            backgroundColor:
                Highcharts.defaultOptions.legend.backgroundColor || '#2B1B17',
            innerRadius: '60%',
            outerRadius: '100%',
            shape: 'arc'
    exporting: {
        enabled: false
    tooltip: {
        enabled: false
    // the value axis
    yAxis: {
        stops: [
            [0.1, '#55BF3B'], // green
            [0.5, '#DDDF0D'], // yellow
            [0.9, '#DF5353'] // red
        lineWidth: 0,
        tickWidth: 0,
        minorTickInterval: null,
        tickAmount: 2,
        title: {
            y: -70
        labels: {
            y: 16
    plotOptions: {
        solidgauge: {
            dataLabels: {
                y: 5,
                borderWidth: 0,
                useHTML: true
// The speed gauge
var chartSpeed = Highcharts.chart('chart-temp', Highcharts.merge(gaugeOptions, {
    yAxis: {
        min: 0,
        max: 60,
        title: {
            text: 'ºC'
    credits: {
        enabled: false
    series: [{
        data: [0],
        dataLabels: {
            format:
                '<div style="text-align:center">' +
                '<span style="font-size:80px">{y}</span><br/>' +  //TAMAÑO NUMERO DE ABAJO
                '<span style="font-size:12px;opacity:0.4">ºC</span>' + //tamaño unidades
                '</div>'
        tooltip: {
            valueSuffix:'TEMP'
// Updating the graph
setInterval(function () {
    var point,
        newVal,
        inc;
    if (chartSpeed) {
        point = chartSpeed.series[0].points[0];
        inc = Math.round((Math.random() - 0.5) * 100);
        newVal = point.y + inc;
        if (newVal < 0 || newVal > 200) {
            newVal = point.y - inc;
        point.update(temp);
}, 2000);
//----------------------------PLOTLY GRAPH------------------------
function plot(temp){
  var data = [
    value : temp,
    title: { text: "Temp" },
    type: "indicator",
Plotly.newPlot('prueba', data, layout);
setInterval(function(){
  getReading_temp();
}, 1000);
I did change your variable res for mine, temp
  var data = [
    value : temp,
    type: "indicator",
This is how it is display
ps.
I change:
to:
Because leaving the var temp will affect the other two graphs, displaying them like this:
I really don’t know why this happened.
Thank you again for your help.
You can have as many var temp as you want as long as they are local like in the example above but…
your issue is not here .
I can bet that you don’t have a key “temperature_c” in jour variable named “Temperatura” as I have in my named “status” :slight_smile:
My JSON rsults looks like this for example:
{bat: 4.03, MQ2: 10.01, humidity: -15.12, pressure_pKa: 1032.37, temperature_c: 19.64, …}
MQ2: 10.01
altitude_m: 925.99
bat: 4.03
charg: 80.58
humidity: -15.12
__proto__: Object
As you can see I have a key in my variable “status” which is "temperature_c"
Firstly we wlii have to see jour JSON results from your var “Temperatura”
To get that, simply unmark console.log(“temp”, temp); in callback_temp() function.
and then try this :slight_smile:
<html>
  <head>
  <body>
  <style>
            #MQ2 {
                float:left;
                width:33%;
            #altitude_m{
                float:left;
                width:33%;
            #bat{
                float:left;
                width:33%;
             #charg{
                float:right;
                width:33%;
             #humidity{
                float:right;
                width:33%;
             #pressure_pKa{
                float:right;
                width:33%;
             #temperature_c{
                float:left;
                width:33%;
        </style>
 <div>
 <div id="MQ2" ></div>
 <div id="altitude_m" ></div>
 </div>
 <p>
 <div id="bat" ></div>
 <div id="charg" ></div>
 <p>
 <div id="humidity" ></div>
 <div id="pressure_pKa" ></div>
 <p>
 <div id="temperature_c" ></div>
  </body>
var accessToken = "xxxxxxxxxxx"; //not display for security
var deviceID = "xxxxxxxxxxxx" //not display for security
var tiempo = 50;
var tiempo_r= 1000;
var layout = { width: 300, height: 200, margin: { t: 0, b: 0 } };
//TEMPERATURA
    plot(temp);
  else {
function plot(chupacabra){
  for (key in chupacabra ){
   var data = [
    value: chupacabra[key],
    title: { text: key },
    type: "indicator",
 Plotly.newPlot(key, data, layout);
getReading_temp();
}, tiempo_r);
    </script>
  </head>
</html>
Make sure that your "div id " is exactly the same as your keys in your variable named "Temperatura"
Also par name in function plot(usududu) can be any :slight_smile:
Here how is looks like:
Thank you very much!!
