Im using my photon and a html page to display my temperatures on my page, but when i try to display both temperatures at the same time, it only displays my second temperature. This is my code for my photon and html:
PHOTON CODE:
int analogvalue = 0;
int analogvalue2 = 0;
int LED_2 = D1;
double tempP = 0;
double tempP2 = 0;
int LED_1 = D0;
Particle.function("led",ledToggle);
Particle.function("led2",led2Toggle);
Particle.variable("temp", tempP);
Particle.variable("temp2", tempP2);
Particle.function("fan", FanToggle);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(LED_1, OUTPUT);
pinMode(LED_2, OUTPUT);
analogvalue = analogRead(A0);
tempP = round(((analogvalue * 3.3)/4095)*100);
Serial.print("Le temp interieur est de:" );
Serial.println(tempP );
//Serial.print("\n");
delay(100);
analogvalue2 = analogRead(A1);
tempP2 = round(((analogvalue2 * 3.3)/4095)*100);
Serial.print("Le temp exterieur est de:" );
Serial.println(tempP2 );
delay(100);
int FanToggle(String command)
if (command=="on")
digitalWrite(LED_1,HIGH);
return 1;
else if (command=="off")
digitalWrite(LED_1,LOW);
return 0;
else
return -1;
int ledToggle(String command)
if (command=="on")
return 1;
return 0;
else
return -1;
int led2Toggle (String command1)
if (command1=="on")
digitalWrite(LED_2,HIGH);
return 1;
else if (command1=="off")
digitalWrite(LED_2,LOW);
return 0;
else
return -1;
HTML PAGE CODE:
<!DOCTYPE HTML>
<html>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js" charset="utf-8">
</script>
<body>
<p> La temp est :
<span id="analogue"></span></p><br>
<button id="connectbutton" onclick="myFunction()">Read Temp</button>
<p> La temp2 est :
<span id="analogue2"></span></p><br>
<button id="connectbutton" onclick="myFunction2()">Read Temp</button>
<script>
var myVar;
document.getElementById("analogue").innerHTML = "Lecture de la valeur...";
function myFunction() {
myVar = setInterval(Tstart, 1000);
function Tstart() {
var y = Number(document.getElementById("txt1").value);
var deviceID = "<--redacted-->";
var accessToken= "<--redacted-->";
var varName = "temp";
requestURL = "https://api.particle.io/v1/devices/" + deviceID + "/" + varName + "/?access_token=" + accessToken;
$.getJSON(requestURL, function(temp1) {
document.getElementById("analogue").innerHTML = temp1.result + "C";
document.getElementById("analogue").style.fontSize = "28px";
if (temp1.result >= y) {
document.getElementById("analogue").style.color="red";
} else {
document.getElementById("analogue").style.color="black";
var myVar2;
document.getElementById("analogue2").innerHTML = "Lecture de la valeur...";
function myFunction2() {
function Tstart() {
$.getJSON(requestURL, function(temp2) {
document.getElementById("analogue2").innerHTML = temp1.result + "C";
document.getElementById("analogue2").style.fontSize = "28px";
</script>
<p>
y =
<input type="text" id="txt1" name="text1" >
<p>
<form action="https://api.particle.io/v1/devices/<--redacted-->/led2?access_token=<--redacted-->" method="POST" target="_blank">
Communiquer avec le photon!<br>
<br>
<input type="radio" name="arg" value="on">Allumer la fan
<br>
<input type="radio" name="arg" value="off">eteindre la fan
<br>
<br>
<input type="submit" value="Valider!">
</form>
<br>
<form action="https://api.particle.io/v1/devices/<--redacted-->/led?access_token=<--redacted-->" method="POST" target="_blank">
<br>
<input type="radio" name="arg2" value="on">Allumer LED
<br>
<input type="radio" name="arg2" value="off">eteindre LED
<br>
<br>
<input type="submit" value="Valider1!">
</form>
</body>
</html>
