Help! Photon with Nokia 5110 LCD
I can't get this to work!!!
and I don't know where to start, Im pretty new with the photon, actually just a couple of days since I recieved it.
I'm using this library:
,GitHub - dgsmith/SparkCore-Nokia5110LCD: An Implementation of SparkFun's Nokia 5110 Library for the Spark Core
I read this full thread:
@FistOfTheNorthStar said that he could connect them together without modifications, I tried it... and nothing...
when I looked for the library I found this: "The Serial data and Serial clock pins should stay at the default A3 and A5, respectively." so I thought that FistOfTheNorthStar was wrong (he inverted A3 and A5)
I'm using firmware 0.4.5 and I'm could flashing
I'm kind of stucked, any help?
PLEEEAAASEEE!!!!
Did you get any help here?
@eirikso are you having some issues using it? I have one working on my table :slight_smile:
For the people ending here after searching: yes, I had issues but got help from @kennethlimcp over in the original thread: Nokia 5110 DIsplay (Graphic LCD 84x48 from Nokia 3310) [SOLVED]
