Help on Cloud command CURL
Dear forum,
I am facing a problem, which I try to solve . Unfortunately my knowledge in curl is limited. I am following an example of Particle of turning a led ON and OFF using the curl in command line.
I would like to implement this to a RESTrequest can someone advice me what would be the BaseURL to use for the post method?
I am using .Net to send this command with POST method using a button.
The Particle example CURL is : curl https://api.particle.io/v1/devices/0123456789abcdef/led
-d access_token=123412341234
-d params=on
My .Net button sends with POST method the following but it does not work, do you know what I am writing wrong?
https://api.particle.io/v1/devices/0123456789abcdef/led?access_token=123412341234&params=on
Regards
John
The -d options to curl put the data in the POST body, not the URL, as text data of type application/x-www-form-urlencoded data.
So your URL would be: https://api.particle.io/v1/devices/0123456789abcdef/led
And the POST body data would be:
Hi , thanks for the fast reply,
I only have one place to put the URL, it is not like HTML5 which I can seperate them . In my example I have to put the URL to a string and then post it.
Lets say you use a Visual Basic programming , how should you send the http post?
Because when I use the GET , to read an analogue value my URL is only one.
https://api.particle.io/v1/devices/0123456789abcdef/analogue?access_token=123412341234
Hi ! I have just found out how to do it!
thank you very much!
It was a mistake in the parameters value.
Yes, but that's a GET request, which can be handled as a singe string. A POST request needs to be treated differently, for good reasons. How to use that with visual basic can be found here, if anyone's still interested: Make HTTP requests with the HttpClient - .NET | Microsoft Learn
