Hi all,
I have a particle photon with a simple program installed that can control my ceiling fan. It used to work with IFTTT, but that is no longer an option for me. Now (years later) I am trying to figure out how to use a URL string to push a command (via homeseer) like "1f" to my particle device. I've been reading and experimenting half the day and am stuck.
I created and access token and tried using it, but it does not appear to be working. If someone could please walk me through this, I would be truly grateful.
* Code to control Harbor breeze Saratoga ceiling fan using a Particle Photon. Code should work for and Harbor
* Breeze fan with the 6 speed remote <https://images-na.ssl-images-amazon.com/images/I/41GdQZ4%2BDwL.jpg>
* Components used:
* Particle photon: https://www.amazon.com/gp/product/B016YNU1A0/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
* RF transmitter (315Mhz): https://www.amazon.com/gp/product/B00LNADJS6/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
* Device wiring:
* https://gethookblog.wordpress.com/2015/10/30/hook-early-beta-testing/
* All credit goes to the following:
* veggiebenz @ http://www.instructables.com/id/Reverse-Engineer-RF-Remote-Controller-for-IoT/
* veggiebenz @ https://bitbucket.org/veggiebenz/fancontrol/src
* Rahil from Hook Smarthome
* To control the fan:
* 1. Go to a command prompt that talks to the photon (in my case windows command prompt
* 2. Type the command without parenthesis
* particle call (device id or device name) Transmit (command)
* 3. Commands include light, power, 1f (speed 1 forward), 5r (speed 5 reverse), etc
* To control from the internet using IFTTT just setup a trigger and look for "particle"
* IFTTT will connect to your particle easily and will run the Transmit function. Just
* define which command you want to send. I use google home to voice activate the fan
* this way.
const int TX_PIN = D3; // Particle photon pin 3
typedef struct {
boolean power;
int duration; // micro seconds
} signal;
const signal SHORT_ON { true, 400 };
const signal SHORT_OFF { false, 500 };
const signal LONG_ON { true, 850 };
const signal LONG_OFF { false, 950 };
const int REST = 10000;
const char* host = "fancontrol";
signal sig_preamble [] { // 50 items total
SHORT_ON, LONG_OFF, SHORT_ON, LONG_OFF, SHORT_ON, LONG_OFF, SHORT_ON, LONG_OFF,
signal sig_light [] {
SHORT_ON, LONG_OFF,
SHORT_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_power [] {
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_1f [] {
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_2f [] {
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_3f [] {
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_4f [] {
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_5f [] {
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_6f [] {
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_1r [] {
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_2r [] {
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_3r [] {
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_4r [] {
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_5r [] {
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_6r [] {
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_breeze [] { // runs in the forward direction
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_breeze_reverse [] { // runs in the reverse direction
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_house [] {
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF
signal sig_delay [] { // This button will turn off the light and fan after 1 minutes (works if light is on or off)
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_2h [] {
SHORT_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF
signal sig_4h [] {
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF
signal sig_8h [] {
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF
signal sig_summer [] {
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF,
LONG_ON, LONG_OFF
signal sig_winter [] {
LONG_ON, SHORT_OFF,
LONG_ON, SHORT_OFF,
LONG_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
SHORT_ON, LONG_OFF,
LONG_ON, LONG_OFF
// This routine executes transmission of the code out to the RF transmitter
// Signal sent in 3 pcs PREAMBLE + SIGNAL + POSTAMBLE
void doTransmission(signal array[16]) {
Serial.println("Doing transmission...");
for (int burst = 1; burst <= 6; burst++) {
for (int pre = 0; pre < 32; ++pre) { // transmits the Preamble
digitalWrite(TX_PIN, sig_preamble[pre].power);
delayMicroseconds (sig_preamble[pre].duration);
for (int idx = 0; idx < 16; ++idx ) { // transmits the payload (signal command)
digitalWrite(TX_PIN, array[idx].power);
delayMicroseconds( array[idx].duration );
digitalWrite(TX_PIN, SHORT_ON.power); // transmits the postamble - is that a word?
delayMicroseconds(SHORT_ON.duration);
digitalWrite(TX_PIN, SHORT_OFF.power);
delayMicroseconds(REST); // rest between bursts
// This routine is called from the windows command line using the following string (leave out the < and > symbols)
// particle call <device_id> Transmit <command in yellow below>
int Transmit(String cmd) {
if (cmd == "light"){
doTransmission(sig_light);}
else if (cmd == "power"){
doTransmission(sig_power);}
else if (cmd == "1f" || cmd == "low"){
doTransmission(sig_1f);}
else if (cmd == "2f" || cmd == "medium low"){
doTransmission(sig_2f);}
else if (cmd == "3f" or cmd == "medium"){
doTransmission(sig_3f);}
else if (cmd == "4f"){
doTransmission(sig_4f);}
else if (cmd == "5f" || cmd == "medium high"){
doTransmission(sig_5f);}
else if (cmd == "6f" || cmd == "high"){
doTransmission(sig_6f);}
else if (cmd == "1r" || cmd == "low reverse"){
doTransmission(sig_1r);}
else if (cmd == "2r" || cmd == "medium low reverse"){
doTransmission(sig_2r);}
else if (cmd == "3r" || cmd == "medium reverse"){
doTransmission(sig_3r);}
else if (cmd == "4r"){
doTransmission(sig_4r);}
else if (cmd == "5r" || cmd == "medium high reverse"){
doTransmission(sig_5r);}
else if (cmd == "6r" || cmd == "high reverse"){
doTransmission(sig_6r);}
else if (cmd == "breeze" || cmd == "circulate"){
doTransmission(sig_breeze);}
else if (cmd == "breeze reverse" || cmd == "circulate reverse"){
doTransmission(sig_breeze_reverse);}
else if (cmd == "house"){
doTransmission(sig_house);}
else if (cmd == "delay"){
doTransmission(sig_delay);}
else if (cmd == "2h"){
doTransmission(sig_2h);}
else if (cmd == "4h"){
doTransmission(sig_4h);}
else if (cmd == "8h"){
doTransmission(sig_8h);}
else if (cmd == "summer" || cmd == "forward"){ // respond to either summer or forward command
doTransmission(sig_summer);}
else if (cmd == "winter" || cmd == "reverse"){ // respond to either winter or reverse command
doTransmission(sig_winter);}
else {
return -1;} // returns -1 if unrecognized command was sent
return 1; // returns 1 for a successful command
// nothing to loop
pinMode(TX_PIN, OUTPUT); // required for output, deleting will cost you hours of pain...
Particle.function("Transmit", Transmit); // defines the transmit function
