Hello, I recently got a photon and I’ve been working on porting some of my code over from other micros I’ve used. I’m currently trying to get a little menu system I made ported over and I seem to be having some issues getting it working properly. This code works fine on the other boards I’ve used so its a little confusing.
The problem seems to be within the setFunc
function. It doesn’t seem to update when changing menus. I have it setup to copy a function pointer array to the current_func
array, I’ve tried a couple things and not had any luck. It seems to work one time and then not again. If anyone has any suggestions they would be greatly appreciated. I’ve posted all the code below. Thanks!
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_DC D5
#define TFT_CS D4
#define TFT_MOSI A5
#define TFT_CLK A3
#define TFT_RST D6
#define TFT_MISO A4
#define up D3
#define down D2
#define select D1
#define UP 1
#define DOWN 2
#define SELECT 3
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
bool appRunning = false;
int selected; // currently selected menu item
int upButtonState = 0;
int downButtonState = 0;
int selectButtonState = 0;
char* current_menu[255] = {0};
uint8_t current_menu_index = 1; // current position in the array
uint8_t current_menu_size;
bool page_change = false;
uint8_t menu_top = 35; // top space between title and items
typedef void (* CurrentFuncPtr) (); // Function pointer for current menu
typedef void (* PassFuncPtr) (); // Function pointer for current menu
typedef void (* MenuFuncPtr) (); // Function pointer for Main Menu
typedef void (* Test1FuncPtr) (); // Function pointer for Test Menu 1
typedef void (* Test2FuncPtr) (); // Function pointer for Test Menu 2
// function prototypes
void setMenu(char** menu, uint8_t size);
void setFunc(PassFuncPtr* funcs, uint8_t size);
void buildTestMenu1(void);
void buildTestMenu2(void);
void returnMainMenu(void);
char* mainMenu[3] = {" Main Menu",
"Test Menu 1 ",
"Test Menu 2 "
char* testMenu1[4] = {" Test Menu 1",
"Option 1 ",
"Option 2 ",
"Back "
char* testMenu2[4] = {" Test Menu 2",
"Option 1 ",
"Option 2 ",
"Back "
CurrentFuncPtr current_func[255] = {NULL};
// Main menu func pointer
MenuFuncPtr menu_func[3] = {NULL,
buildTestMenu1,
buildTestMenu2};
// Test menu Func Pointer
Test1FuncPtr test1_func[4] = {NULL,
buildTestMenu2,
buildTestMenu2,
returnMainMenu};
Test2FuncPtr test2_func[4] = {NULL,
buildTestMenu1,
buildTestMenu1,
returnMainMenu};
// Button Setup
pinMode(up, INPUT_PULLUP);
pinMode(down, INPUT_PULLUP);
pinMode(select, INPUT_PULLUP);
tft.begin();
tft.setTextWrap(false);
tft.setRotation(3);
tft.setTextSize(3);
setMenu(mainMenu, sizeof(mainMenu)/sizeof(char *)-1);
setFunc(menu_func, sizeof(menu_func)/sizeof(char *)-1);
displayMenu();
void menuInput(void) {
// read the state of the pushbutton value:
upButtonState = digitalRead(up);
downButtonState = digitalRead(down);
selectButtonState = digitalRead(select);
if (upButtonState == LOW) {
// Up
action(UP);
else if (downButtonState == LOW) {
// Down
action(DOWN);
else if (selectButtonState == LOW) {
selected = returnSelected();
action(SELECT);
delay(100);
while(!appRunning) {
menuInput();
void returnMainMenu(void) {
displayMenu();
void buildTestMenu1(void) {
setMenu(testMenu1, sizeof(testMenu1)/sizeof(char *)-1);
setFunc(test1_func, sizeof(test1_func)/sizeof(char *)-1);
displayMenu();
void buildTestMenu2(void) {
setMenu(testMenu2, sizeof(testMenu2)/sizeof(char *)-1);
setFunc(test2_func, sizeof(test2_func)/sizeof(char *)-1);
displayMenu();
void setMenu(char** menu, uint8_t size) {
memset(current_menu, 0, size);
int i;
for(i=0; i<=size; i++) {
current_menu[i] = menu[i];
selected = 1;
current_menu_size = i-2;
void setFunc(PassFuncPtr* funcs, uint8_t size) {
memset(current_func, 0, size);
Serial.println(size);
int i;
current_func[i] = funcs[i];
void displayMenu(void) {
int i;
tft.fillScreen(ILI9341_BLACK);
tft.setCursor(0, 0);
tft.setTextColor(ILI9341_GREEN, ILI9341_BLACK);
tft.println(current_menu[0]);
tft.drawLine(0, 25, tft.width()-1, 25, ILI9341_GREEN);
tft.setTextColor(ILI9341_YELLOW, ILI9341_BLACK);
for(i = current_menu_index; i <= (current_menu_index + 6); i++) {
tft.setCursor(0, ((i - current_menu_index) * 30) + menu_top);
tft.println(current_menu[i]);
menuHighlight(selected);
void menuHighlight(uint8_t index) {
if (page_change == false) {
tft.setCursor(0, ((selected - current_menu_index) * 30) + menu_top);
tft.println(current_menu[selected]);
tft.setCursor(0, ((index - current_menu_index) * 30) + menu_top);
tft.setTextColor(ILI9341_YELLOW, ILI9341_BLUE);
tft.println(current_menu[index]);
selected = index;
int returnSelected(void) {
return selected;
void action(uint8_t action) {
switch (action) {
case 1: { // up
if (selected <= (current_menu_index + 6) && (selected > current_menu_index)) {
menuHighlight(selected - 1);
else if ((current_menu_index > 1) && (selected <= current_menu_index)) {
current_menu_index = (current_menu_index - 1);
selected = selected - 1;
page_change = true;
displayMenu();
break;
case 2: { // down
if (selected >= (current_menu_index + 6) &&
(current_menu_size > 6) && (selected <= current_menu_size)) {
current_menu_index = (current_menu_index + 1);
selected = selected + 1;
page_change = true;
displayMenu();
else if ((selected < (current_menu_index + 6)) &&
menuHighlight(selected + 1);
break;
case 3: // select
menu_func[selected]();//
break;
