I have a program that has been working fine, yet I continue to try and improve it. The program is used to monitor my garage doors, alert us when one opens and remind us of when one is left open (particularly important at night).
There are two garage doors (left and right) and I'm sensing opening/closing via YoLink devices. I then use IFTTT to send messages via webhooks to my particle device (Argon running 4.2.0). It used to work, but now I finding the application does not appear to be receiving the GDRC (garage door right closed) event. Using the command line particle subscribe GDRC I can see the event is coming into my account, but it isn't being seen by my program. I'm put in some extra Particle.publish() statements in an effort to localize the issue, but without success. Everything seems to work except receiving the GDRC event message. Thoughts? The logic is pretty simple although the enlightened might shudder at my coding.
Here's the evidence the events are coming into my account:
{"data":"somedata","ttl":60,"published_at":"2023-11-14T18:39:49.118Z","coreid":"api","name":"GDRC"}
{"data":"somedata","ttl":60,"published_at":"2023-11-14T18:46:21.654Z","coreid":"api","name":"GDRC"}
{"data":"somedata","ttl":60,"published_at":"2023-11-14T18:58:08.772Z","coreid":"api","name":"GDRC"}
{"data":"somedata","ttl":60,"published_at":"2023-11-14T19:00:04.944Z","coreid":"api","name":"GDRC"}
{"ttl":60,"published_at":"2023-11-14T19:04:30.266Z","coreid":"api","name":"GDRC"}
{"ttl":60,"published_at":"2023-11-14T19:05:37.264Z","coreid":"api","name":"GDRC"}
{"ttl":60,"published_at":"2023-11-14T19:23:47.307Z","coreid":"api","name":"GDRC"}
{"ttl":60,"published_at":"2023-11-14T19:24:29.732Z","coreid":"api","name":"GDRC"}
I'm including the program code in case someone is interested in seeing and advising me what I obviously can't see. Is there anyway the "GDRC" event is reserved for special use?
#include "Particle.h"
#include "neopixel.h"
SYSTEM_MODE(AUTOMATIC);
SerialLogHandler logHandler;
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_PIN D0
#define PIXEL_COUNT 24
//#define PIXEL_TYPE SK6812RGBW
#define PIXEL_TYPE WS2812B //this is required for the neopixel ring I own
#define BRIGHTNESS 5 // 0 - 255
#define __FILENAME__ (strrchr(__FILE__, '/') ? strrchr(__FILE__, '/') + 1 : __FILE__)
#define doorOpenTime 3600000 // 60 minutes * 60 seconds * 1000 ms
//#define doorOpenTime 60000 // 1 minutes * 60 seconds * 1000 ms -- for testing!!!
#define closed 1
#define open 0
int solenoid = D8;
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
int hour = 0;
int minute = 0;
int second = 0;
uint32_t color = 0;
uint32_t lights[30];
int i=0;
uint32_t blue = 0xFF;
uint32_t red = 0xFF00;
uint32_t green = 0xFF0000;
char gDeviceInfo [200];
int gAction = 0;
int gDoorStillOpen = 0;
int gLGD = closed;
int gRGD = closed;
boolean gChimeOn = true;
void doorOpenStill(); //prototype
Timer doorOpenLongTimer(doorOpenTime,doorOpenStill);
pinMode(solenoid,OUTPUT);
Time.zone(-5); //EST
Particle.function("pulseSolenoid",pulseSolenoid);
//Particle.function("setPixelsRed", setPixelsRed);
//Particle.function("setPixelsGreen", setPixelsGreen);
//Particle.function("setPixelsBlue", setPixelsBlue);
//Particle.function("setPixelsOff",setPixelsOff);
Particle.function("openRight", openRight);
Particle.function("closeRight", closeRight);
Particle.function("openLeft", openLeft);
Particle.function("closeLeft", closeLeft);
Particle.function("pReset",pReset);
Particle.function("enableChime",enableChime);
Particle.variable("deviceInfo",gDeviceInfo);
Particle.variable("DoorStillOpen",gDoorStillOpen);
Particle.variable("RGD",gRGD); //right garage door status
Particle.variable("LGD",gLGD); //left garage door status
Particle.variable("chimeStatus",gChimeOn);
Particle.subscribe("waterLeak",waterLeak,MY_DEVICES);
Particle.subscribe("GDLO",leftDoorOpened,MY_DEVICES); //Left garage door opened
Particle.subscribe("GDLC",leftDoorClosed,MY_DEVICES); //Left garage door closed
Particle.subscribe("GDRO",rightDoorOpened,MY_DEVICES); //Right garage door opened
Particle.subscribe("GDRC",rightDoorClosed,MY_DEVICES); //Right garage door closed
Particle.subscribe("GDC",bothDoorsClosed,MY_DEVICES); //Both doors closed
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
gAction = 7;
snprintf(gDeviceInfo, sizeof(gDeviceInfo)
,"Application: %s, Date: %s, Time: %s, System firmware: %s, SSID: %s, RSSI: %d"
,__FILENAME__
,__DATE__
,__TIME__
,(const char*)System.version() // cast required for String
,(const char*)WiFi.SSID() // cast not required but always safe when in doubt if String or char*
,WiFi.RSSI().rssi
Log.info("setup() completed");
switch (gAction)
case 0: //do nothing
gAction = 0;
break;
case 1: // door opened
//turnLEDSoff();
chime();
//gAction = 5; //set LEDs red
gAction = 0;
break;
case 2: // doorOpenStill
gDoorStillOpen = 1;
// turnLEDSoff();
chime();
delay(750);
chime();
delay(750);
chime();
gAction = 0; //set LEDs red
break;
case 3: // bothDoorsClosed
gDoorStillOpen = 0;
for (uint16_t i=0;i<PIXEL_COUNT;i++){
strip.setPixelColor(i,0,128,0); //green
strip.show();
gAction = 0;
doorOpenLongTimer.stop();
break;
case 4: // pulse solenoid
chime();
gAction = 0;
break;
case 5: // set pixels red
strip.setPixelColor(i,128,0,0); //red
strip.show();
gAction = 0;
break;
case 6: //set pixels green
strip.show();
gAction = 0;
break;
case 7: //set pixels purple
strip.setPixelColor(i,128,0,128); //blue
strip.show();
gAction = 0;
break;
case 8: // set pixels off
turnLEDSoff();
gAction = 0;
break;
case 9: // water leak - chime and set LEDs to blue
turnLEDSoff();
chime();
delay(750);
chime();
delay(750);
Particle.process();
chime();
delay(750);
chime();
delay(750);
Particle.process();
chime();
delay(750);
chime();
delay(750);
Particle.process();
chime();
delay(750);
chime();
delay(750);
Particle.process();
chime();
gAction = 10;
break;
case 10: // set pixels blue
for (uint16_t i=0;i<PIXEL_COUNT;i=i+2){
strip.setPixelColor(i,0,0,128); //blue
strip.show();
gAction = 0;
break;
case 11: // left garage door open
Particle.publish("case11");
for (uint16_t i=PIXEL_COUNT/2+1;i<PIXEL_COUNT;i=i+1){
strip.setPixelColor(i,255,0,0); //red
strip.setPixelColor(0,255,0,0);
strip.show();
chime();
gAction = 0;
gLGD = open;
doorOpenLongTimer.start();
break;
case 12: // right garage door open
Particle.publish("case12");
for (uint16_t i=1;i<PIXEL_COUNT/2+1;i=i+1){
strip.show();
chime();
gAction = 0;
gRGD = open;
break;
case 13: // left garage door closed
Particle.publish("case13");
strip.setPixelColor(0,0,128,0); //green
strip.show();
gAction = 0;
gLGD = closed;
if (gRGD==closed) {
break;
case 14: // right garage door closed
Particle.publish("case14");
strip.show();
gAction = 0;
gRGD = closed;
if (gLGD==closed) {
break;
default:
gAction = 0;
void chime() {
if (gChimeOn) {
digitalWrite(solenoid,HIGH);
delay(50);
digitalWrite(solenoid,LOW);
void turnLEDSoff () {
strip.setPixelColor(i,0,0,0); //off
strip.show();
void doorOpened(const char *event, const char *data) {
gAction = 1;
void leftDoorOpened(const char *event, const char *data) {
gAction = 11;
// doorOpenLongTimer.start();
int openLeft(String command) {
leftDoorOpened(" ","");
return 1;
void rightDoorOpened(const char *event, const char *data) {
Particle.publish("receivedGDRO");
gAction = 12;
int openRight(String command) {
rightDoorOpened(" ","");
return 1;
void leftDoorClosed(const char *event, const char *data) {
gAction = 13;
int closeLeft(String command) {
leftDoorClosed(" ","");
return 1;
void rightDoorClosed(const char *event, const char *data) {
Particle.publish("receivedGDRC");
gAction = 14;
int closeRight(String command) {
rightDoorClosed(" ","");
return 1;
void bothDoorsClosed(const char *event, const char *data) {
Particle.publish("receivedGDC");
gAction = 3;
void doorOpenStill() {
gAction = 2;
void waterLeak (const char *event, const char *data) {
gAction = 9;
int pulseSolenoid (String command) {
gAction = 4;
return 1;
int setPixelsRed (String command) {
gAction = 5;
return 1;
int setPixelsGreen (String command) {
gAction = 6;
return 1;
int setPixelsBlue (String command) {
gAction = 7;
return 1;
int setPixelsOff (String command) {
gAction = 8;
return 1;
int enableChime(String command) {
if (command=="on") {
gChimeOn = true;
return 1;
else {
gChimeOn = false;
return 0;
int pReset(String command) {
//function to call to remotely reset device
System.reset();
return 1;
