callen
October 24, 2016, 1:51am
1
My Code:
/* Includes ------------------------------------------------------------------*/
#include "NCD2Relay/NCD2Relay.h"
NCD2Relay relayController;
SYSTEM_MODE(AUTOMATIC);
int triggerRelay(String command);
void arlsHandler(const char *event, const char *data);
//String arlsDr = "Straight";
/* This function is called once at start up ----------------------------------*/
Particle.function("controlRelay", triggerRelay);
Particle.subscribe("arls", arlsHandler, MY_DEVICES);
// Particle.variable("arlsDirec", arlsDr);
Serial.begin(115200);
relayController.setAddress(0,0,0);
/* This function loops forever --------------------------------------------*/
int triggerRelay(String command){
if(command.equalsIgnoreCase("turnonallrelays")){
relayController.turnOnAllRelays();
return 1;
if(command.equalsIgnoreCase("turnoffallrelays")){
relayController.turnOffAllRelays();
return 1;
if(command.startsWith("setBankStatus:")){
int status = command.substring(14).toInt();
if(status < 0 || status > 255){
return 0;
Serial.print("Setting bank status to: ");
Serial.println(status);
relayController.setBankStatus(status);
Serial.println("done");
return 1;
//Relay Specific Command
int relayNumber = command.substring(0,1).toInt();
Serial.print("relayNumber: ");
Serial.println(relayNumber);
String relayCommand = command.substring(1);
Serial.print("relayCommand:");
Serial.print(relayCommand);
Serial.println(".");
if(relayCommand.equalsIgnoreCase("on")){
Serial.println("Turning on relay");
relayController.turnOnRelay(relayNumber);
Serial.println("returning");
return 1;
if(relayCommand.equalsIgnoreCase("off")){
relayController.turnOffRelay(relayNumber);
return 1;
if(relayCommand.equalsIgnoreCase("toggle")){
relayController.toggleRelay(relayNumber);
return 1;
if(relayCommand.equalsIgnoreCase("momentary")){
delay(300);
return 1;
return 0;
void arlsHandler(const char *event, const char *data){
//Serial.printlnf("%s: <%s>", (const char*)event, (const char*)data);
if(strcmp(event, "arls") == 0 && strcmp(data, "on") == 0){
}else if(strcmp(event, "arls") == 0 && strcmp(data, "off") == 0){
callen
October 24, 2016, 1:55am
2
From the console:
{“name”:“arls”,“data”:“off”,“ttl”:“60”,“published_at”:“2016-10-24T01:47:12.597Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“off”,“ttl”:“60”,“published_at”:“2016-10-24T01:47:31.700Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“on”,“ttl”:“60”,“published_at”:“2016-10-24T01:47:40.863Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“off”,“ttl”:“60”,“published_at”:“2016-10-24T01:48:17.670Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“off”,“ttl”:“60”,“published_at”:“2016-10-24T01:53:04.438Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“on”,“ttl”:“60”,“published_at”:“2016-10-24T01:53:08.126Z”,“coreid”:“001”}
{“name”:“arls”,“data”:“on”,“ttl”:“60”,“published_at”:“2016-10-24T01:53:28.852Z”,“coreid”:“001”}
Who is publishing the event that is subscribed?
ScruffR
October 24, 2016, 11:26am
5
Do you see your device when doing particle list in that CLI session?
You should always have some unconditional code path in the handler to see if it gets called at all (like your commented Serial.print() - which looks familiar )
void arlsHandler(const char *event, const char *data) {
} else if(strcmp(event, "arls") == 0 && strcmp(data, "off") == 0) {
What version CLI are you using?
How are you publishing?
particle publish eventName dataPayload
-- or
particle publish eventName dataPayload --private
callen
October 24, 2016, 12:31pm
6
I was using the non private cli call. And yes the code is the same one from the product I was creating.
Have you tried private then?
Since you are subscribing MY_DEVICES you would need to Particle.publish(evtName, data, PRIVATE) from a device, so it would be just consistent to do the same with CLI.
callen
October 24, 2016, 4:01pm
8
particle publish arls on --private
Ran this and no joy… Is the syntax wrong somehow?
This is what I get
$> particle publish arls on --private
Published private event: arls
Hence again
callen
October 24, 2016, 4:07pm
10
I get the same return as you and I am running 1.16.0
ScruffR
October 24, 2016, 4:38pm
11
With this slightly adapted handler
char txt[64];
snprintf(txt, sizeof(txt), "%s: <%s>", (const char*)event, (const char*)data);
Particle.publish("received", txt, PRIVATE);
I tried these commands
$> particle publish arls off
Published public event: arls
And got the expected result
callen
October 31, 2016, 2:08am
12
Yes I see it in list. I’ve been in the country of Panama for the week. I will resume this process this week. @ScruffR thanks for that insightful coding!
