Guidance on Wifi/5G signal placement best practices
So, at one point I think there was an external antenna planned for the Tachyon, without it I am kind of scratching my head now on best placement of the device.
I was planning on connecting the Tachyon through the HAT to a daughter board which has a bunch of connectivity / ICs on it. It looks like the WiFi antenna is right next to the HAT connector. One side of my device is basically a display, which may block signals. The HAT would sandwich it between some copper.
Instead of a board sandwich through the HAT I could use a cable, and leave the board somewhat more open to the enclosure.
Below is my current thinking, which is to still mate the two devices with the HAT/Header. I could also flip the whole things the Tach is “facing the back of the screen and on the left” if that makes sense. My concern is I have found screens tend to just kill wifi signals being a sheet of metal on the back.
As much as I found the external antennas on the earlier devices annoying they made this problem a bit more straight forward :slight_smile:
Let’s call this the “fun one” as I was playing around keeps the wifi a bit more close to the edge of the enclosure. I should note I do need access to both of the MIPI ports.
Lastly, the board does not seem to get super warm, but I am now getting to the overall board layout stage and am curious about thermals, does the Tachyon normally need active cooling? a heat sync? or just ambient, if something more than ambient does one side get hotter than the other?
Hi @RyanLM,
It might take some experimentation to determine the best board placement based on your project’s specific requirements (enclosure, HAT, carrier board, etc.).
Regarding thermals, this post is helpful to get an idea of the output of the device under load. If needed, you can connect a cooling fan to the 40pin header and configure it with software.
