Grove Multichannel Gas Sensor Library Issues [Cloud disconnection]
Hello,
I am using Grove official library for Arduino, with Photon to interface with that sensor.
Grove Multichannel Gas Sensor Wiki
For first a few minutes, it works fine. I can read all the data without any problem.
But after a short while, Photon randomly disconnects from cloud and reconnects to the cloud.
But it is inevitable that after a few random cloud disconnections, it forever stuck in green rgb light.
I took a look at their cpp file but found nothing suspicious as far as my knowledge goes.
Can any expert suggest which is the actual culprit behind those cloud disconnections?:sweat:
Link to library code
Thanks in advance.
@phyo_tz, the library code includes a lot of jumps which can create loops. There are also several delay() calls which can cause cloud timeout. One solution is to run your
code with SYSTEM_THREAD(ENABLED).
Hello Phyo_tz, can you please provide with working library for particle photon. Best regards
