Granular Per-Device Data Usage in Product SIM Management Tool?
Hey! Super excited to see the release of the fleet SIM management tool the other day. I just entered a SIM into it to play around a bit, and wasn’t able to find any way to see more granular per-device usage stats. Is there any way to see per device usage for SIMS managed by the Product SIM tool? As far as I can tell its only possible to see total fleet usage.
A strong use case for more granular data would be diagnosing individual devices that are using way too much data, or knowing if a device will exceed its data limit. In our case, data usage is pretty configuration driven, so per device stats will be super helpful.
@jeiden
Hey @beck,
Thanks for the ping, glad you are taking advantage of the new SIM management tools! You’re correct – as of now there is only tools for fleet-wide SIM data usage. Down the road, we will likely add the ability to see SIM-level data usage.
Jeff
Thanks for confirming. Just curious, is there a timeline for the SIM-level usage feature?
Not at the moment.
Hey @beck ,
Check out: https://docs.particle.io/reference/api/#get-data-usage
There is a newly documented endpoint for getting usage data per-SIM in a product fleet. Enjoy!
GET /v1/products/:productIdOrSlug/sims/:iccid
Woohoo thats great news! Looking forward to using more of Particle’s SIM management API
