GPS GY-NEO6MV2 wrong readings
I’m developing a “thing” that uses the GPS GY-NEO6MV2 module. I’m using the TinyGPS library with electron an photon. I’m using three of those modules and the readings are like these:
latitude: 1.6665, longitude: 0
latitude: 0.4, longitude: 2.966667
latitude: 0.366667, longitude: 0
latitude: 0.016667, longitude: 0
Is there any situation where I get these readings and I’m missing? Could be an ampereage issue where the module is no able to work in a proper way ?
Let me ping someone that might be able to help, @rickkas7 or @ParticleD are you able to assist?
I have no idea; it’s impossible to say. The TinyGPS parser is generally good, though I use the TinyGPS++ version.
That’s one really cheap GPS module! I’ve never used it, however.
Which module would be a better alternative ?
